Blog/article SEO location/city
Figured I’d work on my articles/blogs and start updating my website. Thought these might be nice to help with SEO I plan to make one article for each major town in my radius, and focus on key towns to pop up on google search. Seeing how the blog flows, is it to wordy, is the picture with the credit given an eye sore? I almost feel like this should be shorter. Its not a technical article. just a quick fluff article to help with SEO.
warning long reply :zany_face:
I have several blog posts in the works for my own website with the same idea in mind, SEO… A few that are already posted need work in that regard. It’s an ever-evolving game that can be tricky. Personally, I think your blog post is pretty good, but have some suggestions based on what I have learned on the subject of SEO. Keep in mind, I am definitely no SEO expert, but I did stay at a Holiday Inn once :wink:.
I have a couple of SEO plug-ins for my site to help with that sort of thing, which is supposed to help, IDK. For what it’s worth, I plugged your first paragraph into one of them that has an AI assistant, and it came up with this:
Here’s a revised version of your text that’s easier to read, more engaging, and optimized for SEO (using natural keyword variations like “home inspection in Little Falls,” “common home inspection issues,” “foundation problems,” etc., while keeping it concise and readable):
Common Home Inspection Issues in Little Falls, MN
Little Falls features a diverse mix of older homes and mid-century properties, many built decades ago. This charming Central Minnesota community offers character-rich housing, but age and regional climate can lead to certain recurring concerns.
During home inspections in Little Falls, Northway Home Inspection frequently identifies these common issues:
  • Foundation movement — Settling, cracking, or shifting due to soil conditions and Minnesota’s freeze-thaw cycles.
  • Outdated electrical systems — Older wiring, panels, or components that may not meet modern safety standards.
  • Aging roofing materials — Wear from harsh winters, potential leaks, or ice dam problems.
These are typical findings in older homes across the area and often manageable with proper maintenance or repairs. A thorough professional inspection helps buyers spot them early and plan accordingly.
This version improves readability with:
  • Shorter sentences and paragraphs
  • Bullet points for scannability
  • Clear headings/subheadings
  • Strategic, natural keyword placement for search engines (e.g., targeting “home inspection Little Falls” or “common issues in Little Falls homes”)
  • Flows better for website/blog content
___________________________________________________________________________
Another thing I would change is the image and description. Use photos in webp format rather than jpeg. On a phone the image size is good, but on a desktop it’s small. It should adjust to screen size automatically. I would use a photo that is from spring or early summer so out of staters don’t get the impression that Little Falls is in the arctic. Instead of having the descriptive text in small font below the picture, just have it in the alt data / alt text / meta description of the image. To me, the way you have it now makes it look cluttered and out of place. Put your photo source citation at the bottom of the page after all of your text, keeping it simple and short. Something like “Photos courtesy of blah blah blah” and make the photographer’s name or source a hyper link rather than doing both like it is now.
As I understand it, Googoo will rank you higher for being an authority on specific topics. A good way to do this, supposedly, is by making other posts that specifically talk about things mentioned in this post and creating internal links to those posts. Example, when you mention efflorescence, make the word itself a link to a post that you wrote about efflorescence, describing what it is, what causes it, etc…
Lastly, if you are only mentioning let’s say 3 issues found during inspections, put that number in the title or header. Something like “Top 3 issues homebuyers should know.” I guess numbers trigger something in peoples brains to click away, in turn, boosting SEO scores.
Happy creating!!!
Just an FYI, in your infrared section, you are a bit inconsistent with commercial and residential.
Discover hidden issues with our infrared inspection services. Our experienced team detects electrical faults, water ingress, and energy losses in commercial and industrial buildings.
I have to work on my website.
Do you possess a Level 1 or Level 2 IR Certification?
Typically, you will need Minimum Level 1 for Commercial, and Minimum Level 2 for Industrial work.
Stuff most Home Inspectors “skate by” on for Residential, have little chance in hell of getting these jobs without proper certification, and/or staying out of trouble!!
Same here. :wink: Good times :upside_down_face:
I didn’t go through the whole site but noticed while looking at it on my phone, something stood out. On the bottom of the home screen, under MENU, there’s no menu. When on a PC, the menu list is there. Not sure if it’s an android thing or a general mobile compatibility issue.
same, i’ll have to fix that *(iphone)
