IMO it is caring about what you are doing. It really does not take that much more time to do a nice job than it does to do a so-so job.
Many years ago, about 1977, no exactly 30 years ago, I wired my house that I built, all alone. Yes, I even wired the electric service panel, nice and neat, very cleanly done. When I had the inspector check everything out, he said that I had bent most of the wires going to the circuit breakers with too sharp a radius. I had bent the wires around a one inch diameter dowell. Well, he didn’t like that, saying that too sharp a bend is bad for the insulation, but he would not make me re-wire the panel. Could he do that, make me re-wire the panel?
George Maher
Home - Safe Home, L.L.C.
Fargo, ND
Not according to the NEC. Cables have a minimum bend radius, but conductors do not.
Thanks, Marc!
I didn’t think he was right, but sometimes you never know. Thanks for your reply. I liked the job I did, and I know his eyes lit up when he first saw it.
George Maher
Fargo, ND
ELECTRICAL SHOCK HAZARD DUE TO STRAY CURRENT](http://www.mikeholt.com/documents/powerquality/Shock_Stray.pdf)
becoming sensitive to noise and stray current generated. voltages. To fully
comprehend and understand the problem of. uncontrolled flow of electric current …
Welcome to IEEE Xplore 2.0: Electrical shock hazard due to stray …
Electrical shock hazard due to stray current Zipse, D.W. Zipse Electr. Eng.
Inc., West Chester, PA;. This paper appears in: Industrial and Commercial Power …
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=787218
Electrical shock hazard due to stray current - Industrial …](http://ieeexplore.ieee.org/iel5/6376/17055/00787218.pdf?arnumber=787218)
and stray current generated voltages. To promote full comprehension of the problem
of. uncontrolled flow of electric current over the earth, the human …
A Review of Stray Voltage, Effects on Livestock - Michigan …
For this review, all available research on the effects of stray voltage on …
Review of all research publications on effects of electrical current on …
http://www.egr.msu.edu/age/MAEC/review.html
Sources of Stray Electrical Currents that Lead to Damage by …
SOURCES OF STRAY ELECTRICAL CURRENT. THAT LEAD TO DAMAGE BY ELECTROLYSIS. Roy E.
Hanson Jr. Mfg. AN EQUAL OPPORTUNITY EMPLOYER 1600 E. Washington Blvd., …
Marc’s image is VERY neat…but they need to re-identify those “White” conductors on the breakers…
But…very neat “Remote Distribution Panel” in a metal stud installation
“Stray Current” is a nonsense term generally applied when a more correct term should have been more properly used. Akin to a person calling a part a “thing-a-ma-jig”, when he doesn’t know the real name.
When I think about stray current I think about the current that is leaking from an underground conductor or those emitted from radio signals.
Then you’d be more properly thinking of an earth fault and RFI.
