Does the bonding wire from the gas pipe to the cold water pipe have to be #6 copper on a 100 amp service. I inspected a house today and noticed someone had used #2 insulated wire.
If that is a proper way to bond gas in Canada then bigger is not a problem.
Maybe Cookie can confirm if that is proper in Canada.
Never seen it that large up here .
This might just have been a short piece of cable that he wanted to use up instead of throwing it in the scrap.
…Cookie
No harm being over sized
Can a gas line be bonded right to a water pipe, or does it need to go to a GEC or panel?
To an copper cold water pipe.
…Cookie
Roy and Speedy Pete are correct, bigger is OK smaller is not!!
