Originally Posted By: jkline
Check out this video. What happens when the TPR valve doesn’t work (or isn’t allowed to work).
http://www.waterheaterblast.com/
Originally Posted By: jwilliams4
“not just an inspection, but an education”
Originally Posted By: rcooke
| jkline wrote: |
| Check out this video. What happens when the TPR valve doesn't work (or isn't allowed to work).
http://www.waterheaterblast.com/ |
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: dandersen
Originally Posted By: jhugenroth
Originally Posted By: Jay Moge
Originally Posted By: sspradling
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
| sspradling wrote: |
| Great video. I wonder, though..if the water heater was set up in the open, instead of in a "mortar tube" of earth, would it have been so dramatic? For instance, when a round of modern ammunition is subject to heat (like in a fire) to the point of ignition, the explosive force of the gunpowder is barely strong enough for pieces of casing to pierce a cardboard box, and the bullet goes almost nowhere. But confined by the chamber and closed breach of a rifle, the pressure can exceed tens of thousands of pounds per square inch, and the only place to vent that pressure is the end of the barrel. That's what drives the bullet. I'm not suggesting that an exploding water heater in the house is not a deadly situation, especially if it's a gas fueled. I'm just suggesting that the demo was very dramatically staged.
Stu |
Roy Cooke Sr.
Originally Posted By: lewens
Just my usual 12.5 cents
Originally Posted By: gporter
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
