Bootlegged Breaker? Pics
How would you write it. Not to mention the splices, burnt neutral etc.
Have licensed electrician evaluate and replace improper setup of disconnect.
I don’t see any sense in using a 2- pole breaker. You have (1) 120 leg coming in and only (1) 120 leg coming out.
Jeff
What you are looking at is a parallel overcurrent device which is non-code compliant
Thanks,
For the replies.
