how much of a difference will there be if I brick veneer vs solid brick my home when it comes to ho insurance? will my insurance be a lot more? is my home brick veneer if the space between brick n block is one inch? how can I tell if its veneer
Only your insurance company can answer you insurance question.
Brick veneer shows regular brick patterns. Solid brick construction shows rows of butt ends of brick every few courses. These bricks laid end wise tie the two wyths together
( might not be using the proper terms here)
Hope this helps
Cheers
