Damn Joe, you post in a poetry format! I’m amazed that no one else has noticed this! From now on, would you please post in iambic pentameter?
You have me scratching my head over that as poetry statement Kenton???
I am still looking at it as a limerick.
you walked a roof
**of indeterminate age and condition
**As she sat there with her lips just Alicken
and caused damage
that resulted
She ran screaming ASPHALTED ASPHALTED
Can’t finish the rest without rewording.
That would be copyright infringement YOU KNOW.
We do not need Michel Larson over here ranting. HA HA HA.
in water intrusion
and interior damage of finish materials."
Different style of reporting
when deferring for review…
there is also a comment
- Recommend obtaining estimations for roof replacement at this time.
- Recommend replacements be made prior to closing.
The roof may be functioning
as you suggest…
But to wait for an indication of leakage?
Just like tires,
I replace and recommend replacement prior to failure.
My tire guy tells me when I’m ready, he dosen’t make me change them.
Prior to closing? Sounds like an indication of a “significant defect”, which it really is not (unless it’s leaking right now).
My state requires:
State any systems or components so inspected that do not function as intended, allowing for normal wear and tear, or adversely affect the habitability of the dwelling;
(iv) State whether the condition reported; a.requires repair or b.subsequent observation, or c. warrants further investigation by a specialist;
I think that b. is more approperate than a. and the inspector should be good enough not to have to do c.!
Look all properly installed roofs will outlast the warranty fr 10 to 12 years of life expectancy.
( maintenance ). I worked commercial roofing for 4 seasons. We did some old roofs and we did not fall through them Mr. Hagarty.
By using car tires as an example hurts your argument even more.
Just like tires,
You must have made a mistake Joe.
Please think again because that makes no sense.
You can see tires right. Even use a gauge to measure the tread depth, look at the sidewalls, check see if the cap is de-laminating.
You are not even looking at the roof let alone any elements atop.
