Buried LP Tank
New Construction.
New Installation of a buried LP Tank at the lowest area of the side yard. Grade slopes from all sides towards the top of the tank.
Is there a chance it could “float” out of place? Is it bouyant?
What did you recommend here Joe?
Well it sure makes it easy to check for leaks.
Defective Installation.
http://www.suburbanpropane.com/images/pdf_lit/NPGA412-94.pdf#search=%22buried%20lp%20tank%20installation%20guidelines%22
