Just had the third time where my Flir Bcam SD went into Grey mode .
Two small lines up center of screen and I could not shut it off. removed Battery and camera then works fine .
Just wondered has any one else had this happen.
Still waiting since Nov for my certificate from FLIR CANADA.
Will be contacting them but wanted to hear if any one else has had any of these things .
I think it stays in a stand-by mode for a while after you shut down. I think mine did it when it was recovering from a shut down that was a bit extended.
The same thing happened to me as well, maybe we should contact Flir about this problem.
I also have not received my certificate from Flir (ITC). The e-mail I received from Paul Frisk stated “Congratulations” on passing Level 1 but you and Roy will not receive a certificate
Seriously, I called Paul and he said they were a little behind and that we would receive it soon!!
</IMG>Hang in there Roy, its only a document!! You know you passed!
