I’m currently taking the ‘How to Inspect for Moisture Intrusion Course’, and have a question pertaining to ‘Section 2.3’ (moisture-Resistant Wall systems). In this module listed under ‘STEP 2: ASSESS BUILDING EXPOSURE’ there is a chart labeled 'Table 7 - Building Exposure Levels’, which I’ve attached. My question is: how do you read the ‘Overhang Ratio’ column - what is it expressing specifically?!
Any help would be appreciated!
Table%207|493x500
The over hang ratio is the ratio of the width of the overhang to the height of the wall. So a 8’ wall with a 4’ overhang has a ratio of .5 . 8’ wall with a overhang of 2’ has a ratio of .25. Think of it as a percentage of the height so for a 8’ wall 4’ overhang is 50% or .50 and 2’ overhang is 25% of 8’ so it would be .25. The way you calculate this is divide the width of the overhang by the height of the wall so 2/8=.25 4/8=.5 or a ten foot wall with a 18" overhang is 1.5’/10’=.15 or 18"/120"=.15 . I hope this helps.
Kevin,
That you for the explanation - makes much more sense now.
Best Regards
Kevin
Rodney,
Thank you - I appreciate it!
I’ve been in this course for a month. Every time I read it ZzZzZzZzzzz after like 10 minutes. It’s a great course, but at the end of the day man oh man is it good for sleeping.
