8" diameter in the middle of a new build poured basement slab. Stub-outs for a future bath are nearby, The X in the bottom won’t budge - though it looks like it’d screw into place. Also visible off to the bottom of the pic is a flush cover plate.
Backwater valve by Sioux Chief.
Did you test it?
Thanks for the ID - and how would you go about testing it? Don’t think i would…
There is no testing without removal and cleaning the unit. Not something a home inspector would be doing.
I concur with Stephen. PVC commercial backwater valve.
I open residential backwater valves when I can. Typically/usually the cap at the bottom of the riser is recommended by the manufacturer to be installed hand tight for routine maintenance.
