How know if have a combined Carbon Monoxide and Smoke alarm? How test a combined Carbon Monoxide alarm and a smoke alarm. Know that smoke alarms are 3 beeps; carbon monoxide alarms are 4 beeps. How many beeps are combined alarms. Hard to see the label on a ceiling alarm as generally use a thin stick to test. How know combined? Do you have separate reporting sections for Smoke and CO alarms?
The detector/alarm is generally labeled as smoke and CO if combined. If not labled, simply state you could not confirm the existence of CO detectors. Recommend install as needed.
Many thanks.
Often a ceiling alarm is not accessible for viewing.
Also just found out by calling one of the manufacturers — a combined alarm will first beep 3 beeps then 4 beeps.
Regards,
Bob Lam
Bob Lam Solutions
[email protected]
(703) 201-2121
More important than pressing the test button on the alarm is determining how old it is. Alarms ten or more years old should be replaced. All alarms are dated on the back (mounting) side. At this time it will also be revealed if it is a combination alarm and if it is hardwired w/battery backup (recommended), battery only and if it is a 10 year battery.
Pressing the test button merely tells you it has power and makes a noise.
Time to UP your game!
Just as important, are the smoke detectors ionization, photoelectric, or both?
Unless the home was built in 2016 or later (in my state) I always recommend smoke (ionization and photoelectric) detectors be installed in appropriate places, and if needed, CO detectors as well.
I can you you joined internachi in 2021, so what have you been doing for 5 years?
You should start with the ability to write in understandable english. Your sentence is really hard to understand and missing many words to make it a complete sentence.
Also, you do take photos right? Take a photo of the alarm, zoom in to verify if it is a combo alarm or not. Also yes you should have a report section for smokes and C/O alarms. Under my electrical section, I have a subsection for smoke and carbon monoxide alarms.
What report software have you been using that does not include this in their simple included template. You should be running a internachi template at the very least. That way you are not missing required items.
I simply report if smoke alarms and carbon monoxide detectors are present or not. I do not test them. If missing, I report it as a safety issue. If I cannot detemine if carbon monoxide detectors are present or not, I say so and advise them to ensure they are present at move-in. If the house is older, I simply recomend the client replace all alarms with new ones.
Smoke and CO alarms are one of those curious “things” in our biz. Our SoP excludes inspecting them. But they are important safety devices. So, do we just point at the SoP and move on, or inspect the devices. In a large home with ten foot or higher ceilings, it can be a bit of a chore to test them all. I kinda do the in-between inspection on them. I’ll press the test button on one unit. In “newer” houses, I listen to confirm they are interconnected. It’s a bit illuminating, how often the unit I select to test, doesn’t respond. And if you decide to adhere strictly to the SoP, and you see one with the battery compartment open, or it’s beeping, do you just shrug and move on?
Corey, thank you sir. Good answer. Have gotten some replies that ridicule me for even asking the question. Don’t understand but some folks are just like that.
Regards,
Bob Lam
Bob Lam Solutions
[email protected]
(703) 201-2121
Many thanks. You and others helping me beaucoup.
Regards,
Bob Lam
Bob Lam Solutions
[email protected]
(703) 201-2121
