Chimney Clearance
This chimney terminated about three feet from this opened skylight. I found several references to vents terminating near openable windows, but can’t find anything about chimneys. I know it’s wrong, but would like to have a reference. :slight_smile:
The only reason I don’t see it as a problem is the chimney and skylight would most likely not be used at the same time. Either it is too cold so you have a fire or it is too hot and you open the skylight. It will be interesting if anyone finds something on this installation. Maybe in the skylight installation instructions.
I would fall under this.
Chimneys shall extend at least 2 feet higher than any portion of a building within 10 feet.
I think it would fall under this.
Stephen - That makes sense, but we can’t rely on common sense now can we LOL!
Chris - It was at least 3 feet high, and 2 feet higher than anything within 10 feet. That part was OK.
If fumes from a plumbing vent are considered dangerous, oil boiler exhaust must be too. Right???
[quote=“bsmith, post:5, topic:59902”]
Isn’t that the truth. Something along the lines of “Don’t stick hand under running mower”… Whatever happened to survival of the fittest? :wink: :mrgreen:
Thats how I would look at this…
Jim
