# Chimneys 101
**URL:** <https://forum.nachi.org/t/chimneys-101/73818>\
**Category:** Exterior Inspections\
**Created:** [December 3, 2012, 2:21am UTC](https://forum.nachi.org/t/chimneys-101/73818 "2012-12-03T02:21:13Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![prussell](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/prussell/32/309158_2.png) [@prussell](https://forum.nachi.org/u/prussell)\
**Post date:** [December 3, 2012, 2:21am UTC](https://forum.nachi.org/t/chimneys-101/73818/1 "2012-12-03T02:21:13Z")
</div>
Interesting chimney failure on yesterdays inspection. Not sure if the footing failed or it was caused by years of leaking. I was lucky enough to get a good image of one of the steel straps that gets embedded into the mortar joint and holds the chimney to the exterior wall. I can only imagine the deterioration to the wall sheathing.
Also, the chimney has been repaired as I could see what looked like Binz, blueish grey paint, on the white chimney and obvious signs of water penetration.
![Rawson 024 (Small).JPG](https://global.discourse-cdn.com/internachi/original/3X/8/e/8ead66d2eca27902d1842ddc614022aaf25ff7be.jpeg)
 ![Rawson 028 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/6/7/67f1cd1c828b15b5886687ca2103718e9b8087d2.jpeg)
 ![Rawson 029 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/9/3/93fd5d4b550e1c8e90734f756db28fe131b4ac79.jpeg)
 ![Rawson 022 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/d/d/ddc2f7e1e48e1a53522bd15779baf0fac4b6fce9.jpeg)
**Post date:** [December 3, 2012, 2:23am UTC](https://forum.nachi.org/t/chimneys-101/73818/2 "2012-12-03T02:23:46Z")
</div>
Cracks at the base of the chimney as well as cracked drywall on both sides of the interior.
 ![Rawson 030 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/d/f/dfdf371e8702033d6caa955ccfe3c20ed1a7b3e9.jpeg)
 ![Rawson 105 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/4/a/4aad78448d743820f5e93ffbbc6a6b6be8fdd5c0.jpeg)
 ![Rawson 106 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/e/8/e8e343ac8ce8778cd71490e9df248e4f46bd02b1.jpeg)
 ![Rawson 031 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/2/0/20dab09351f5e157c811db36c7aace8284d85cca.jpeg)
**Post date:** [December 3, 2012, 2:34am UTC](https://forum.nachi.org/t/chimneys-101/73818/3 "2012-12-03T02:34:23Z")
</div>
Here’s a couple more that shows just how much it’s separated from the wall and the different shades of white where attempts were made to repair/cover up the moisture.
I like the way the way they stuck the J channel in backwards to hide the gap!!!
![Rawson 026 (Small).JPG](https://global.discourse-cdn.com/internachi/original/3X/3/7/37e0ecd5bb82a745a7260e5563c3ef9f81729d2c.jpeg)
![Rawson 032 (Small).JPG](https://global.discourse-cdn.com/internachi/original/3X/f/b/fb2bdfc9a9aae679c02d6e2dbe79fdb6edc4f962.jpeg)
 ![Rawson 034 (Small).jpg](https://global.discourse-cdn.com/internachi/original/3X/4/c/4ca8a2061d1ee5730190da51e2a4df298f626a5f.jpeg)
**Post date:** [December 9, 2012, 6:51am UTC](https://forum.nachi.org/t/chimneys-101/73818/4 "2012-12-09T06:51:50Z")
</div>
Peter it was a combination of maintenance issues, pour building practice.
The ash pit door is at ground level. Not for that climate.
The shoulders are rotten.
Lets play the home inspector detective.
First I will make 2 comments.
#1 The chimney was an after thought? OR #2 They did not install in properly. It should have been masonry course bonded into the wall if there is one. If not it should have been anchored into the structure.
That would stop the chimney from pulling away from the structure. I suspect after thought. Many reasons why.
#1 Lot slope and gravity. Is the lot reversed sloped? That would be my first observation for an hypotheses.
Look at the ash pit. Should be in the basement if there is one.
Way to high. Condensation = Water will freeze inside when the chimney cools and creates RH from the exterior tempt change. It a dam door.
#2 The shoulders are rotten. Water will enter the cavity between the masonry and the wall that is behind the chimney.
I see they painted the brick. Its a no no.
After thought chimney I suspect.
I could go on but why.
SUSPECT: defective chimney. shoulders are defective in application and build.
Defects: Shoulders, masonry bed bond lateral and serpentine cracking above the ash pit clean out the width of the chimney.
The chimney is leaning xx degrees away from the homes main structure.
The brick masonry does not seem to be tied into the structure with anchorage. There is a gap that runs laterally in height of the chimney gaining in separation from the base being the smallest separation to the peak or the gable being the widest in separation at xxx inches…yada …yada yada,
RECOMMEND: A licensed mason evaluate if the chimney can be salvaged.
If it for a furnace it can be strapped to the unit and a liner used.
This may be danger and health hazard to the home owners and also allow water and weather to enter into the structure.
All the best…
