system
(system)
#1
Originally Posted By: bking
Are circuit breakers considered unsafe if they are enclosed in a small metal box (with only the levers exposed) that is flush mounted inside the wall?
They are inside a upper kitchen cabinet that has the back cut out around the electrical box.
Actually they look like FPE breakers (main panel is FPE stab-lok) so I guess it does not matter..... unsafe for FPE reasons too.
comments needed on the installation assuming non-FPE breakers please.
thanks
www.BAKingHomeInspections.com
system
(system)
#2
Originally Posted By: bbadger
I can not imagine anyway that could be done within the rules of the NEC or safely.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
system
(system)
#3
Is this a small listed flush mount panel or some field assembled cludge of parts?
Can you remove the cover without tearing out the finish?
Are the breakers readily acceessible?
system
(system)
#4
Originally Posted By: jpope
Did they look like this?
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
system
(system)
#5
They look newer than Jeff’s picture, and appear to be FPE type. It would require ripping out the cabinet to work inside the box.
I reported that they are to be replaced along with the rest of the panels in this house.
