I’m looking to buy a CO detector. What types are good and which ones should I stay away from. Any ideas out there???
I have a TIf 8900. It works great. I have detected aprox 6 gas leaks since I started. It is essential for home inspectors.
The Tif 8900** doesn’t** detect CO… it only detects **Combustible **compounds…
http://www.inspectortools.com/ProductDetails.asp?ProductCode=TI8900&gclid=CMP-wbGJvbMCFcxAMgodAgcAlA
Partial List of Detectable Compounds w/minimum detectable concentration
- Acetylene 50 ppm
- Iso-Butane (R600a) 500 ppm
- Methane 500 ppm
- Ethane (R170) 500 ppm
- Propane (R290) 500 ppm
- Ethylene 500 ppm
- Hydrogen 500 ppm
- Methyl Ether 500 ppm
- Vinyl Chloride 5 ppm
- Methyl Chloride 5 ppm
- Hydrogen Sulfide 5 ppm
- Acetone 50 ppm
- Methanol 50 ppm
- Ammonia (R717) 20 ppm
- Gasoline 1 ppm
- Chlorine 1 ppm
Okay great I will look into it further thanks for the info.
Hmm never really thought about that. The TIF 8900 will detect leaks from heat exchangers, flues, natural and propane gas lines. I can’t imagine you need anything more. From what I have heard, some inspectors don’t have anything!
I use a rattler. Works great and I can hook it to my belt.
http://www.indsci.com/t40/
I’ve never owned one. I’m still alive and so are my clients.
Don’t work in unfinished, rarely used, sealed off for the winter, basements very often, do you? ![]()
When was the last time you saw an article about a home inspector who died from CO while doing an inspection? Even getting sick?
The last person I am worried about regarding this topic is myself…
As Juan has stated, I am more concerned about my clients, but to address your question… no article, but it has happened to me (sick not died), and to another inspector that I personally know, in my general area. And NO, it wasn’t a Meth house.
Crucify me and attack me all you want but home inspectors should be morally compelled to detect for gas leaks.
Interesting thread. Someone should do a poll to see how many HIs use a CO detector. I’d be interested in knowing. Maybe I’m way off.
I do check for fuel gas and often find leaks.
Go for it.
I don’t believe there has ever been a death from CO because of a cracked heat exchanger…many CO deaths from other causes such as blocked venting, BBQing indoors, cars left running in garages, etc.
I’d like to be proven wrong so send me a link to a reliable article if you have one.
PS - If you do a search on gas detectors you will see previous posts on the problems they can create for you.
There’s a first time for everything. Do you want to be the first inspector in line for this to happen to?
i bet they have caused plenty of headaches… just saying…
Was that a pun?
I agree, and most here prolly thought it was “just” a headache! ![]()
