system
(system)
February 22, 2015, 8:53pm
What is the codes for ground fault interruptors and if there is mold starting to grow on the ceiling of my bathroom due to no ventilation would that be a landlord fault?
wwilson3
(Wayne Wilson, TN 439)
February 22, 2015, 9:01pm
2
Depends on how old the place is for GFCI how ever it is a good practice to be by any water source . Does the bathroom have a window ?
nsnook
(Nate Snook)
February 22, 2015, 10:08pm
3
These are some of the dates when GFI protection became required. This would still depend on when the AHJ adopted these codes.
General guidelines for GFCI-protected receptacles include the following locations:•Outdoors (since 1973)
•Bathrooms (since 1975)
•Garages (since 1978)
•Kitchens (since 1987)
• Crawl spaces and unfinished basements (since 1990)
•Wet bar sinks (since 1993)
•Laundry and utility sinks (since 2005)
jjonas
(Jeffrey Jonas)
February 22, 2015, 11:15pm
4
Don’t blame your landlord for your lack of household cleanliness!
Home >Cleaning Institute >Bathrooms
Bathroom Cleaning Tips
Professional Bathroom Cleaning Tips
Molly Maid has years of experience cleaning bathrooms of all types and sizes. Over that time, we’ve accumulated a lot of wisdom about how to properly clean this area of your home. Some suggestions:
1.Keep a small vacuum near the bathroom and give the floor and any carpets a quick once-over every day.
2.Use a small squeegee after your morning shower to slow the development of water marks.
3.Keep some potpourri, or a fresh candle, in the bathroom for a good scent.
4.A simple nylon netting over the drain in the shower or tub can significantly reduce hair clogs.
How Do You Unclog Shower Heads?
It’s a common bathroom cleaning issue—a low-flow shower head that isn’t designed to be low-flow. Fortunately, unclogging a shower head is easy with our professional cleaning tips.
Simply remove the shower head and place it into a mixture of vinegar and hot water. This will loosen the calcium and other materials clogging the mechanism and allow you to experience a full-force flow once again!
Bathroom Cleaning Schedule
No matter which rooms are included as part of your Molly Maid cleaning service, our goal is to provide a quality clean that makes your entire home feel better. Keep your home maintained in between Molly Maid visits by implementing a consistent cleaning schedule, like this one for a bathroom:
•Daily: After each shower, use a small squeegee to help prevent water marks on the walls. Also keep a small hand held vacuum to use on the floors each day.
•Weekly: Once per week, combine the above duties with a thorough cleaning of the shower/tub, toilet and surfaces. Mop the floor weekly as well.
•Monthly: Once per month, be sure to organize all of your cabinets and closets within your bathroom spaces. This helps maintain an easy order within these storage spaces.
•Yearly: With regular maintenance, a bathroom should not require a deep, yearly clean. Items to clean occasionally include taking down blinds and giving them a soak in all-purpose cleaner and washing your plastic shower curtain in cold water.
Did you know that 63% of Americans hate cleaning bathrooms more than any other room? Click here for more fun facts!
These are just some of the tips we have for keeping a bathroom clean. Our years of professional cleaning have taught us a lot more, and the best way to maintain a bathroom is to clean it consistently. Since you have better things to do, contact your local Molly Maid today!
mcyr
(Marcel Cyr, CMI)
February 22, 2015, 11:18pm
5
Ground Fault Circuit Interrupters are a safety issue that has been introduced for a long time now and recommended for your safety.
Proper ventilation in a bathroom will eliminate the possibility of mold and mildew build up in a bathroom.
It sounds like your questions should be discussed with your landlord to see if they can be addressed properly.
dgrace1
(Derek Grace, CMI)
February 22, 2015, 11:32pm
6
About $20 should buy you a GFCI outlet and a bottle of cleaner…
