I typically combine some of the numerous deficiencies I find in a crappy house. Some of these houses are really old and some are not, but they all suffer from inadequate maintenance combined with poor DYI workmanship. I will group items like “ Overall condition of the composite board siding is in poor condition. Due to possible water intrusion some hidden wall structure may be damaged. I recommend a experienced contractor perform the siding replacement.” I will include some general photos for reference, but I make it clear I do not provide an itemized list of all similar defects. How do other inspectors handle this in the report?
I have a statement in my first page general notes that says something like - I do not take multiple pictures of the same defect. My picture may be an example of a larger concern. In reality though when an item is really prevalent on a house I don’t just include 1 pic, I will put in 2 or 3 of the issue to drive home how serious the concern is.
My report is similar. For example, when the home has cracked block around the exterior, I may include 3 or 4 pics, but in the comment I say “pics may not show every crack present”
And In regards to several different defects, such as with a poor deck, I may make a small bullet list of defects, but state " recommend full evaluation of deck and corrections as necessary"
My reports are broke down by room for the interior sections of a house, so I do call out each defect I find in each room in the report, but I had a house last week where I considered the whole inside of the house a potential health hazard due to strong smell of cat urine & cat feces. In this case I add a general note at the begining of the interior section section of the report stating this.
I’ve had inspections that have taken multiple hours to complete with reports over 100 pages long.
For repeat defects, such as rotted window trim that I saw on multiple windows yesterday, I have a few photos to illustrate what I am talking about and comment that there are multiple examples of this defect or problem. I’ve seen reports with photos of every single nail pop on the roof. Sheesh, that is just not necessary in my opinion.
I’m in the “combining defects” club as well when it makes sense. For instance, a foundation that has numerous larger cracks, some bowing, signs of moisture intrusion, efflorescence, etc. I will put a few pictures with a “Foundation Deteriorated” narrative. Inside the narrative it states that the pictures are a representative sample of some areas.
I do the same.
Where damage, deterioration, or defects extend into adjacent components, I write up the whole mess in the section where it makes most sense. So if I see termite damage in joists, subfloors, and finished floor boards, and I suspect it goes up the wall studs, I write it all up in the structural section, including finishes and the presence of termite activity. Same with rot from a roof leak. Write it all up in the roof section, and cover the framing and finishes damage down through the house in one big deficiency write up. Then in the various other sections, I have a generic note “Observed damage and deterioration associated with [primary deficiency]. See the [Fill in the blank] Section for further details on damages and defects to the [components].”
Personally I try to avoid a massive laundry list of defects if it all stems from one issue, if I can cover them elsewhere in one fell swoop. I also provide opinions of repair costs, so the natural fit for me is to lump repair project tasks together.
I have also Kevin. The sad thing is that they probably are not even read😢
I encountered a deck last week that was sturdy and low to the ground (e.g. < 30") that had a ton of issues. It was pretty obvious that it was not built by a professional, nor was it permitted. If it had been higher off the ground, representing a real fall hazard, I would have spent extra time to document all the issues. But, since the fall hazard was minimal, I used my combined defect narrative:
“The deck appears to be largely non-compliant with modern standards and perhaps not completed with the required building permits. In the inspector’s estimation, the framing should have been better secured together with approved strapping, brackets, hangers, fasteners, and with appropriate flashings. There may be other work that could have been done better. Decks not built to best practices or local standards may be useable at the time of the inspection, however, remedial work is recommended by a qualified contractor to ensure that the deck continues to be safely serviceable.”
which is common with lengthy wordy reports…
I handle it the same way you do.
Until it goes to court ![]()
Rather than poor condition, I narrate what I see.
Widespread lap siding and wood trim damage or deterioration observed. Based on condition, concealed water intrusion related damage is possible or likely. Further damage will occur if not corrected. Recommend replacement of all lap siding and repair or replace any related materials/components as needed by a qualified contractor.
As far as photos, I put in a representative number of photos to help further illustrate the problem. If done correctly, my narrative should stand alone with no need to rely on a photo.
I agree and like this along with our South African friend Carel Broekman… ![]()
I like to tell people why I’m calling it out but it can get exhaustive. Sometimes I just want to say “get a bulldozer”. It’s ok to make a general statement for repairs after on or two things are discovered.
