For you that like to stay within your SOP and not check a washing machine drain line you would have missed this one as it overflowed out the furnace condensate floor drain onto the garage floor. Yes I know you dudes have disclaimers for this but it does not keep your phone from ringing when the first load of clothes were washed by your client and it prevents you from repeat business they call me instead:shock::shock::D:D
David I fill the tub about 1/2 full if the machine is there and I flip it to spin if the drain can handle that its good to go.
I have a rubber washing machine hose with one female end cut off that I use if the home is vacant the cut off end fits into the drain real nice and I loop the hose around the other valve so it does not jump out of the drain with pressure applied. All you SOP guys disregard the above I want your business:D:D
Wayne I do what every it takes to get your business want me to come to TN AND show ya. I was not joking about the cookies, baked chip cookies today with a little help I did not want to waste the heat while testing the oven:D:p
When you do what ever it takes to skin the coon the below type house is what ya get to inspect. 8K in the house 2K in the garage
