Common Signs of Foundation Damage and Repair Solutions
Hey everyone! I wanted to share my experience with foundation repair and offer some insights. One of the most crucial aspects of maintaining a home is ensuring a solid foundation. Here are a few signs that might indicate foundation damage:
  1. Cracks in the walls or floors: Keep an eye out for vertical, horizontal, or stair-step cracks in your walls, especially around door frames and windows.
  2. Uneven or sloping floors: If you notice that your floors are no longer level, it could be a sign of foundation issues.
  3. Doors and windows sticking: Difficulty opening or closing doors and windows, or gaps between the frames and walls, can indicate a shifting foundation.
If you observe any of these signs, it’s essential to address them promptly to prevent further damage. Here are a few common repair solutions:
  1. Foundation underpinning: This involves strengthening the foundation by adding support through piers or helical anchors. It helps stabilize the structure and prevent further settlement.
  2. Mudjacking: Also known as slabjacking, this technique raises sunken concrete slabs by injecting a mixture of grout or foam beneath them, filling any voids and restoring stability.
  3. Waterproofing: Sometimes, foundation damage can be caused by water intrusion. Waterproofing measures, such as installing drain tiles or a sump pump, can help prevent moisture-related issues.
Remember, it’s crucial to consult with a professional foundation repair expert before deciding on the best course of action for your specific situation. Has anyone else dealt with foundation issues? I’d love to hear about your experiences and any additional advice you might have!
Many foundations companies over sell to customers by installing more products than required. My biggest issue is installing basement waterproofing, typically treats the symptoms and not the problem. The latest carbon fiber repair method for basement walls needs to be designed by a structural engineer on every application. Improper application can cause brittle failure in the concrete without warning. Most basements fail due to poor exterior grading and improper backfill with clay soils. Water penetration into the basement needs to be addressed from the outside through better grading, drainage and exterior waterproofing on the foundation walls. IMO every homeowner should hire an independent third party inspection ( home inspector or engineer depending on the issue) to review the problem and check repairs proposals prior to construction and retain their services to ensure proper installation.
