Concrete blocking
Hi, does anyone know why there are holes in the concrete blocking?
. I can not find anything online. TIA
Observation/inspection/re-rod holes for high lift grouting?
Ive seen when they grout these, but the larger ones , it had me guessing
My guess on the larger holes in they needed the space to tie additional steel in the wall.
They are to tie the footing rebar in with the wall rebar. Then they will fill those cells all the way up to the bond beam with concrete. You will typically see them about every 6 feet, at corners, and under both ends of headers for windows/doors
Morning, Tracy hope to find you well. Welcome to the InterNACHI community forum.
Gout in/secure finished rebar work that is not completed.
Still a large pile of sand. Any brick on site?
Ask the builder, buyer, your clients for the plans.
Hi, I was taking pics for the foundation class here, which is around the corner from my house. they mostly do not use any brick for walkways over here, for the sand. I do not know why that is there. I had seen on a few other homes over here that they use holes on the bottom for venting. I still do not know the reasons for the larger holes, if thats the case. I had zoomed into the back hole and it appears to be romex
