Condensate Drain air gap
Is the only solution to this PVC setup for the condensate line that it needs cut and capped near the outlet and moved up with an air gap and condensate pump installed with a wye fitting at the washer and airgap into the wye on one side while washer gets the air break on other side of wye. Also update to studor vents. What’s with that vent before the p trap (upgrade that too since it’s there) can’t see how it’s tied into kitchen sink on other side of wall but it’s to the right of the p trap we see but lower in the wall.
Instead of reusing the PVC pipe can it just be a flexible hose from condensate pump the entire way? Will it make the corner fine and no deform when boiler heat is on in its area ?
The previous installer 9 years ago did it like this and somehow it was fine until water heater went. This new water heater had to add some more PVC and saw water coming back up to water heater with washer on and draining and noticed kitchen sink gurgles when washer drains
The wye pipe already installed with washer hose can have that vent removed and used for condensate air gap drain after raising the other air vent in the wall and replacing with studor; would this be correct? How much would the vent need raised in the wall?This home is 102 years old and the p trap is 30" from the floor. From the top of the p trap it’s 27" to washer drain, very bottom of ptrap to washer is 36"
Here
Did you install the new water heater yourself, and now you’re looking for DIY advice to fix it?
My advice- call a plumber.
Was the old water heater a heat pump type?
I replaced the heater pump that went bad with the same , only difference I did was use flexible to tank after removing last tank and taking it down 50 stairs and taking this 305 lb up and installing it.
I’ve had probably 4 different plumbers over the years and all of them don’t seem to want to touch it and I don’t know why, I was only looking for suggestions on how to do it right since I’m pretty sure it’s not but I’m getting mixed information online so I’m trying to dig through code but the house is 102 years old. Short of ripping it all out I just want it to work as best as a house this old can and just have a proper draining condensate pump instead of this filling drain when my washer is draining
Yes , same heater, was replaced under warranty but I had to take it out and put it in, so many stairs, was terrible. After I did it I had my washer start draining as I was there and noticed it was filling the hose so I pinched it to stop it and started researching. I’m just looking how to do it right please.
I am going to cut and cap the condensate drain at the outlet and then run a flexible hose into a condensate drain and then up and around and drop it above where the washer drain is currently to air gap the condensate pump drain I’d be putting in. Remove that other aav on the right and drop my washer hose in that side since it’s a straight shot to the p trap. Then maybe extend the left aav up another 4 inches or so to be 6" above all fixtures flood line and maybe make it a studor or leave it this type? Oh also update the right pipe to be 2" all the way vs las lt foot being 1.5"
