Originally Posted By: Brian A. Goodman This post was automatically imported from our archived forum.
As far as I know the answer is “never” due to possible cross-contamination, but I see it here and there. I write it up and tell 'em to run it to the exterior like they’re supposed to. Some do it, some don’t.
Cross-contamination also includes gases. I haven’t known it to happen myself, but with no trap the path is there for sewer gases to be sucked into the air distribution system (most HVAC systems being under negative pressure).
I'm no plumbing guru, so pardon me if these are silly questions, but...
If you have an air gap, what's to stop sewer gases from leaking into the attic? Isn't there some prohibition against that in the code?
