There was a panel in the condo with six breakers. Outside next to the electric meters was the panel in the picture. It appears that there is only one main service disconnect, labeled 100 amps, and that each individual condo then has a 30-amp circuit breaker in that panel labeled for it.
Never seen a set-up quite like this one, so I look to the electrical gurus to give me guidance, other than the standard "recommend further evaluation by licensed electrician."
Don't even ask me about that "TV" breaker at the very bottom. ?????
Standard Zinsco disclaimer Russ.
If you pulled the cover, it may have been that there is no main. These type of Zinsco boxes have several way to connect the service wires - back fed, directly to the bus bars and even split busses with parallel service.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
I would guess the TV is for the outlet the house TV distribution amp plugs into, among other things.
If there is no large fixed in place equipment in these condos (all gas appliances, no laundry) the 30a may not really be that out of line. That is 7200va. Figure 3000va for the kitchen and the rest at 3va per sq/ft it could support a 1400 sq/foot unit and still be reasonable. You wouldn’t do that in new construction but if this is old it wouldn’t surprise me.
