How can you tell the difference between a cool deck and a stamped concrete product?
One is a coating that can chip and flake and the other is stamped colored concrete with color through out or just plain concrete.
The thing about cool is, if I havta explain, you wouldn’t understand
cool deck is usually applied using a dash brush with the peaks knocked down after some cure time to create the high-low “drag” pattens
stamped concrete on the other hand uses stencils and dyes when speced to achieve the finished product
search cool deck, kool deck, stamped concrete images for further visual info
you’ll know when walking barefoot
cool deck is usually applied using a dash brush with the peaks knocked down after some cure time to create the high-low “drag” patterns
you’ll know when walking barefoot in the heat of the summer ;~))
