dmacy
(David C. Macy, CMI)
October 28, 2008, 11:37pm
Only a small area of the gas pipe located in the unfinished basement was corroded.
The only thing I could tell was the exterior meter had settled at the seal had broken at the exterior.
There were no other areas of the piping or basement with moisture or corrosion.
What do you think?
bkelly2
(Brian Kelly, AZ Cert. # 60234)
October 29, 2008, 2:53am
2
I think no big deal. If you want you suggest a wire brush and some paint.
jmckee
(James McKee)
October 29, 2008, 3:08am
3
David…I have a few fittings that look just like that at home…there turned that way shortly after I saturated them with those leak detector bubbles…just a thought…jim
dmacy
October 29, 2008, 12:39pm
4
Thats what I had recommended. Thanks!! Good suggestion.
