Originally Posted By: srowe This post was automatically imported from our archived forum.
You bet!
Got home and realized something was missing. It was a builders house and he thought under a cabinet in the kitchen was a good place for it...but you have to move the stove to access it. Actually the whole house had a bunch of quirky things
Originally Posted By: jonofrey This post was automatically imported from our archived forum.
Erby,
I’m almost certain it was in the attic (nowhere else to be found). I just could not see it.
This is what I wrote up on it:
I could not locate the water heater. It is most likely in the attic space above the master bedroom area that is blocked by the air handling unit in the attic and is not currently accessible. The hot water temperature was measured at 115 degrees F. This temperature is lower than the optimal effective temperature of 120 degrees F. The age of the structure is in excess of 20 years, if the original water heater is still in place (likely) it has exceeded it's useful life expectancy and should be replaced. This cannot be verified without access to and inspection of the unit. I could not access the unit to inspect it.
The building code requires that the unit be accessible for service, inspection and removal.
Originally Posted By: dvalley This post was automatically imported from our archived forum.
John,
This happened to me last week. I had five people looking high and low for that dang water heater.
All of the sudden I heard the sellers Realtor yell out, I found it. I went in the bedroom where she was standing and seen that she was holding a 3x6 piece of paneling in her hand. Its right in there she said.
The W/H was placed inside a closet with a sheet of paneling covering it.
Originally Posted By: tallen This post was automatically imported from our archived forum.
Uphill T&P’s are very common here on homes built before 1971. I report that the TP valve should not run uphill and should terminate outside. However nobody ever does anything about it. Same thing with the drip leg. Most homes do not have a drip leg and no one seems to care. I still mention it .
– I have put the past behind me,
where , however, it now sits, making rude remarks.
