Covered above ground spa
Are pool door/window alarms still required for a covered above ground spa or does the cover exempt it from alarm requirements?
From what little I saw on a short webernet search it depends on the cover.
Here’s some pool safety info.
Edit: Florida has the same info:
yeah that’s kind of what I saw too :thinking:
FBC definition of “swimming pool”:
SWIMMING POOL, PRIVATE. Any structure, located in a residential area, that is intended for swimming or recreational bathing and contains water over 24 inches (610 mm) deep including but not limited to inground, aboveground, and onground swimming pools, hot tubs, and nonportable spas.
https://codes.iccsafe.org/content/FLRC2023P1/chapter-45-private-swimming-pools#FLRC2023P1_Pt08_Ch45
Commenting on the spa is outside your SOP. Just make sure it is not going to come back on you. CYA
3.2. Exterior
IV. The inspector is not required to:
L. inspect swimming pools or spas.
So if I’m reading this correctly it depends if the spa cover is ASTM F1346 compliant to qualify for the exemption. which I’m assuming would be listed on the cover
Here are better photos of the pictures above
All references aside, I always mention pool safety when there is a pool.
It would be helpful to know where you’re inspecting. You can add this info to your profile and I highly recommend doing so.
@dgarrett3 I don’t offer pool/spa inspections anymore as an ancillary service but California has a requirement that I have to report on, even though I don’t offer this service and its not included in my SOP. If you’re located in Cali, I can offer an experienced comment.
I’m not in CA but what do they require?
We must report on whether or not at least 2 of the seven listed drowning prevention features have been installed on a home with a pool and/or spa.
"The Seven Drowning Prevention Features are:
** An enclosure that meets the requirements of Section 115923 and isolates the swimming pool or spa from the private single-family home.*
** Removable mesh fencing that meets American Society for Testing and Materials, (ASTM), Specifications F2286 standards in conjunction with a gate that is self-closing and self-latching and can accommodate a key lockable device.*
** An approved safety pool cover, as defined in subdivision (d) of Section 115921.*
** Exit alarms on the private single-family home’s doors that provide direct access to the swimming pool or spa.*
** A self-closing, self-latching device with a release mechanism placed no lower than 54 inches above the floor on the private single-family home’s doors providing direct access to the swimming pool or spa.*
** An alarm that, when placed in a swimming pool or spa, will sound upon detection of accidental or unauthorized entrance into the water. The alarm shall meet and be independently certified to the ASTM Standard F2208, “Standard Safety Specification for Residential Pool Alarms.”*
** Other types of protection, if the protection afforded is equal to or greater than that provided by any of the aforementioned safety features — and independently verified by an approved testing laboratory as meeting the standards established by the ASTM or the American Society of Mechanical Engineers (ASME).*"
I hv a 25 years background in the pool & spa industry. I can tell you that most all straps that lock down the spa cover has a key. Meaning once that strap in locked into place that’s connected to the skirting there is a small key like shaped hole to turn so no one can even open the cover. This is great safety feature to have. Brand new covers are extremely light so children could easily open them.
Did you proofread this post?
Respectfully, No! I looked at the photo of the spa & briefly read the concern about safety concerns. So, I was just simply sharing a tip on how to be more safe. Hope that’s OK?!
Thank you, Brandi
