jramey
(Jason Ramey, CMI®)
May 21, 2018, 2:37am
#1
I’m in California. Every home in my area is either a slab or a crawl. Going through the training I’m a bit lost on the crawl space vapor barrier. Should EVERY crawl space have the full plastic lined vapor barrier installed or only the ones that are encapsulated? If so, do you mark that as a defect or just ‘monitor’?
thanks all!
lkage
(Larry Kage, CMI)
May 21, 2018, 3:38am
#2
jramey:
thanks all!
Just recommend installation of a vapor barrier on the dirt, by a qualified professional and move on to something else.
Of something is supposed to be there and is not, you would not “monitor” it. You would recommend installation by a qualified professional.
Here is some info on different types of crawlspaces: https://www.nachi.org/bbsystem/usrfiles/C/CI-Crawlspace_00-774.pdf
jramey
(Jason Ramey, CMI®)
May 21, 2018, 4:49am
#3
Fantastic info Larry, Thank you. Do vapor barriers only apply to sealed crawls? or do vented ones need them to?
Thank you again for your time.
-Jason
mcyr
(Marcel Cyr, CMI)
May 21, 2018, 2:06pm
#5
You might want to check with your AHJ for your area.
About California Ventilation Building Codes | Home Guides | SF Gate
The California building code states all underfloor areas must be aired by openings in the exterior foundation walls. The openings must have a total area of 1 square foot for every 150 square feet of underfloor.
http://www.cityofconcord.org/pdf/permits/building/trifold.pdf
rlewis5
(Roy Lewis, CERTIFIED MASTER INSPECTOR)
May 21, 2018, 2:09pm
#6
Very rarely do I ever find a vapor barrier.
sbaker2
(Scot Baker, CMI)
May 21, 2018, 4:12pm
#7
Seen less than a handful since I started in Nor Cal.
imayer
(Ian Mayer, CMI)
May 21, 2018, 10:26pm
#8
jramey:
thanks all!
You might want to check with your local building codes.
Vapor barriers are not only not installed, they are NOT recommended in Southern California due to our very dry climate.
You’re much farther North, so it may be different.
