I received a call from a landlord/owner to inspect a single unit in a trip-plex for potential moisture issues. The owner believes the “mold” is a result of tenant neglect and not the building itself. He is looking to cover his ass and prove nothing is wrong with the unit but instead the uncleanliness of the tenant who has been cited for lack cleanliness issues before.
My plan is to go and inspect for any plumbing/ventilation/moisture issues that unit may have. Thermal imaging/moisture and humidity testing as well as all the visual testing that would go along with a normal inspection. I am not testing any areas for “mold”.
If I find evidence that could be causing the issue I will report on it. If I do not find anything obvious, I will report accordingly.
What should I be doing to cover my ass in this situation?
Probably best way to cover yourself is avoid the inspection. These situations often turn into a can of worms, the client wants you to find issues with the tenant and the tenant will want you to find issues with the home.
A little tricky as Michael points out. I was an expert witness a few weeks ago when the landlord wanted me to confirm that he had cleaned up a rental. He was being sued by the tenant. I told him I would just report what I saw and it was pretty straight forward. There is a good chance that the owner will want you to assign blame. Be darn careful with that.
You seem to have a good gameplan, but yea its also a risky job in the sense that you have to be very careful how to word things. Be as up front with your client as possible that you very well may not be able to verify the tenant is at fault.
My first request would be that neither the tenant nor landlord are present for the inspection. That way you can do a thorough moisture intrusion inspection without being “pushed” one way or the other.
The problem here is cause and effect. Home inspectors report on effect (that is visible) and leave the cause part to someone else. In this case you are being asked to determine cause. Are you comfortable (qualified) with that? If not you should pass!
Thank you for the great responses. I am not even mention cleanliness conditions or that the landlords position. The landlord said he almost want to find a reason for this issue so he can fix it but does not believe there is something here for him to fix. I am going into it just like any other inspection and reporting on what I see. I like the idea of doing the inspection solo. That way I can state that in report and better show there was no influence.
Great point! I never have and never intend intend to state cause. I will be reporting on defects. The landlord can take those defects and use them to make determinations how they see fit.
That shows good faith on the part of the landlord. And that’s probably why they are hiring you. They want to know if there is something that needs to be fixed on their end. If it’s looking like the moisture is due to poor “tenant practice,” you could also provide some tips to help the tenant reduce the moisture buildup (run vent fans, open windows, run air exchanger, run dehumidifier, etc..).
