Dead front cover screws, 1 of 6, will not budge. Tips and tricks?
Currently at my last required mock inspection. Don’t worry, I’ll do MANY more on my own before I take a paying job ![]()
Thanks in advance.
Thanks in advance.
If something is not moving, I stop trying.
Most of the times it is because either the incorrect screw was used or they cross threaded the screw. If the screw head accepts a square bit, use that, and make sure you are uning a large enough screwdriver. If you still cannot unloosen it then take a picture of it and note it in the report, though I don’t believe I ever had one I could not remove.
The screws are usually a combo #2 Roberson driver and flathead. It is usually one of two possibilities, the screwdriver is not the right size or you don’t have enough torque. If torque is the problem, you may want to consider carrying a ratchet wrench with the appropriate size tips for tight screws.
Panel cover screws usually go in very tight when they are first threaded into the panel on installation, but usually get easier once they’re removed and reinstalled a couple of times. I agree with others, if you cannot remove it, disclaim it.
Flat heads work better than phillips 9 times out of 10. Even though the slot looks like it can fit a phillips, it is actually designed for a robertson aka square tip, so using a phillips screwdriver has a high chance of stripping the screw slot.
If I can’t remove the panel for any reason (such as screws that won’t come out, panel cover painted to the wall, blocked access like a gun safe against the panel, or whatever reason) I’ll disclaim it and give the reason why. I’ll offer to return for a trip fee ($175 plus mileage) and remind them of the paragraph in my pre-inspection email to the list agent about needing access to the panel, attic hatch and crawlspace hatch.
Typically, the buyer pays the return trip, but they can ask for reimbursement from the seller because the seller was aware of the need for access on the day of the inspection.
Disclaimers are fine, but I do try to get in. I carry a razor/knife and a variety of bit drivers and nut drivers specific to whatever fastener type I might encounter on a panel cover.
I keep these in all my tool kits. They are made specifically for Panel Screws
Five out of six can be removed and the 6th will not budge. You’re done and the screw that can not be removed is written up. The panel interior is disclaimed.
Tips and tricks - You have no idea why the screw will not rotate when it should if you have put enough torque on it. If the screw is a problem you risk the potential of stripping it or the hole opening. You damage it you pay to have it repaired. If you’re willing to do that then by all means use a breaker bar on the end of a ratchet with a screwdriver bit. You’ll either break it free, strip the head, or snap off the head.
I have a cheap electric screwdriver in my bag but I never use it. Instead I use a Commercial Electric 11 in 0ne screwdriver. I like it because all the bits are in one place (including the square drive bit) and it does 5/16 and 1/4 nut driver for screws you would find in most HVAC.
HD and Lowes have the same thing in different brands. Don’t forget a magnet on your belt to hold the loose screws!
Get yourself a good cordless screwdriver, a good one will have more torque than any person.
This is the one I use, it’s been discontinued but there are still some good deals on eBay.
Black & Decker Pivot Plus PD600, Type 2, 6V Cordless DRILL, 3 Positions, 2-Speed | eBay
i had one like that last year. i used a pair of vice grips and got it turned a little bit, then rotated the panel out of the way. i left the screw protruding slightly and let the agent know so they could pass it along. probably not the correct thing to do but i found some aluminum branch wiring and a whole host of other things.
Lately I’ve been finding too many covers installed with something akin to an automotive impact wrench, almost fused in the hole.
That occurs from using pointed screws that get welded in place when it contacts the wrong conductor while installing the screw!!
Those are awesome. Something like that probably would have worked. Thanks
I will. Just wanting to pass the NHIE prior to doing too much financial investment.
Thanks so much
Magnet on the belt, that’s a great idea. Of the 5 inspectors I did field training with, no one had that. Will look into it. Thanks
Reinstall the five out of six fasteners with equal tension/torque. Then try removing the over torqued fastener first. That way the dead front is pretty much evenly torqued to the enclosure.
It has worked for me.
I use a small speaker magnet laced to the tool pouch.
My waste tool pouch has a built in maginet. Great idea Bob.
Was using an appropriate size flat (not Phillips), but realize that I need power for torque and this super cool bit! Does it have a specific name?
