Deckng question
How would you (or would you) report decking material that is buted togeather?
When I was in construction, I always allowed 1/4 inch between deck boards to allow for air flow and expansion in the wet season.
Inspected a new (replacement) deck where the decking material is snug. decking is of pressure treated variety if that makes a difference? This is the “wet” season here in the norhwest, so may shrink a bit when the weather drys out. Seller says deck installed during the summer dryer weather.
Thanks
Not my Job it is not a safety concern so look and move on if the deck has no other issues.
…Cookie
You are correct with the general 1/4 inch spacing, it is to allow water to pass through, to prevent rotting, and ponding
I disagree it can be a safety concern if the water builds up. and then rot sets in.
And then what about WDO’S which that could be a conducive condition in WA, right Steve I did my WDO testing there, I would call it out if the condition was conducive.
I used to build decks with 1/4" but the wood would shrink too much across the grain. I went to 1/8" and had much less trouble. Some of the wood is pretty wet when when you get it.
with pressure treated 5/4" that is wet I always butt it as tight as i can and presto a few months later a near perfect 1/4"gap, just like magic…this only works on wet pressure treated or green lumber…other types must be spaced…jim
I just learned this today check it out regarding your Green lumber.
http://www.cvswmd.org/resident_services/arsenic_faqs.html
James, I was just about to say the same thing.
I agree, with pressure treated lumber, installs should be as tight as possible.
Water content is up in the 30’s and 40’s in some lumber yards.
Marcel :slight_smile: :smiley:
Ditto what James said, 1/4 now is over 1/2 in 3months if you’r talking about 5/4 PT
