Originally Posted By: Morgan Audetat This post was automatically imported from our archived forum.
Please instruct me further, though I have been in the trades for some time I am new to HI.
It seem to me that a GFI is a safety issue and could be defined further using the adjectives major or minor.
Further, if I went along with the statement: "Things that lead to major defects" I would be reminded of my then 86 year old grandmother who warned me that kissing leads to other things. e.g. A fart is not a small gas leak (LP or NG). Point is, many minor defects could become major as a kiss could lead to a little bit pregnant. But in the end you either are, or you are not.
I know that many of you belong to other organizations it would be nice to learn more about their definitions.
Perhaps most important to us as a whole is what the prospective home owner understands to be major. Do you define for them in your agreement or report what the true meaning is?
Originally Posted By: jmyers This post was automatically imported from our archived forum.
Morgan,
I personally make it into a what is important issue, rather than a major or minor defect.
GFCI protection would be an important consideration for the occupants of the house because of the risk of electrocution, that is very important in my book and I stress that to the client(s). Whether or not it is important to them is entirely another story. If $8 can save a life, it is well worth it in my book.
CO detectors would be another in my book that is important for homes that have combustionable appliances. I think the chance is rare that it will ever be needed but it is a possibility and your concerns should evolve around items that are there for their safety and well being.
Both of these things are major to me. I don't know if they will be that important to the client, so all I can do is stress how a little money can save their life.
You can also have the failed roof which costs several thousands of dollars to replace that is considered a major defect. A failed chimney or flue liner that could cost up to several thousands to correct depending on what route you would take.
As you can plainly see, a major defect does not necessarily mean expensive, just important. If you start thinking on the level of importance you will do much better than with the major or minor mindset.
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
I point out the absence of GFIs, or if they are defective. If the home was constructed when the presence of GFIs was mandatory, it is a defect. If the home is older, it is not.
I never call it a major. I point it out as a (1) required item, or (2) strongly recommended item. In both cases, I stress the safety issue.
As to a major defect, I categorize that as anything which is major (roof, main panel, deck, heat, etc), or which may affect the person's ability to occupy or finance. This may be a lack of CO, termites, no smoke alarm, or (now required in NY) no CO detector.
Originally Posted By: mrose This post was automatically imported from our archived forum.
Here is definition I found in some proposed state legislation.
OWNER'S INFORMATION
3-12 1. In this form, 'am aware' means have notice or
3-13 knowledge. In this form, 'defect' means a condition
3-14 that would have a significant adverse effect on the
3-15 value of the property; that would significantly impair
3-16 the health or safety of future occupants of the
3-17 property; or that if not repaired, removed, or replaced
3-18 would significantly shorten or adversely affect the
3-19 expected normal life of the premises.
-- Mike Rose
Cornerstone Home Inspection Co. LLC
Lawrenceville, GA
