Hey Guys,
I was asked to do this because It has been found to be the weakest of the electrical knowledge.
I will be holding an 8 hour class on Demystifying Grounding & Bonding…so if you are able to get together a minimum of 25 people in your area ( for chapter heads ) contact me for details of bringing this to your area.
Class - Understanding Grounding and Bonding…8 Hours with TEST !
Here is what we will cover…with full color illustrations and examples…
***Article 250 Grounding …1
250.1 Scope
250.2 Definitions
250.3 Other Code Sections
250.4 General Requirements for Grounding and Bonding
250.4(A) Summary
250.6 Objectionable (Neutral) Current
250.8 Termination of Grounding and Bonding Conductors
250.10 Protection of Grounding Fittings
250.12 Clean Surface
250.20 Alternating-Current Systems to be Grounded
250.24 Grounding and Bonding at Service Equipment
250.28 Main Bonding Jumper
250.30 Grounding (and Bonding) Separately Derived Systems
250.32 Grounding and Bonding at Separate Buildings and Structures
250.34 Generators – Portable and Vehicle-Mounted
250.50 Grounding Electrode System
250.52 Grounding Electrodes
250.53 Installation of Grounding Electrode System.
250.54 Supplementary Electrodes
250.56 Resistance of Ground Rod Electrode
250.58 Common Grounding Electrode
250.60 Lightning Protection System Grounding Electrode
250.62 Grounding Electrode Conductor - Material
250.64 Grounding Electrode Conductor Installation
250.66 Grounding Electrode Conductor - Sizing
250.68 Grounding Electrode Conductor Termination
250.70 Grounding Electrode Termination Fitting
250.80 Service Enclosures
250.86 Other Enclosures
250.90 General Bonding Requirements
250.92 Assured Bonding – Services
250.94 Grounding of Communications Systems
250.96 Bonding Other Enclosures
250.97 Assured Bonding – Raceways and Cables Containing 277V Circuits
250.100 Assured Bonding – Hazardous (Classified) Locations
250.102 Bonding Jumper Requirements
250.104 Bonding of Piping Systems and Exposed Structural Steel.
250.106 Lightning Protection System
250.118 Types of Equipment Grounding (Bonding) Conductors
When you are done…YOU will FULLY understand the concept and the application…
