Deterioration of Insulation
It this note still in the code?
I found this in an Article 310 note in the "HI Guide" AKA the 1968 NEC?
Quote:
13. Deterioration of Insulation. It should be noted that even the best grades of rubber insulation will deteriorate in time, so eventually will need to be replaced.
I believe that this information could be used as a good reason to support the concerns expressed over the old knob and tube wiring systems.
Do you agree? ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: jpeck
I did not find it in the current code, but it is definite backup for what I’ve been saying.
Thank you, Kind Sir. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Maybe I will not be the only voice saying this now. Nah, someone will still say differently.
Jerry Peck
South Florida
Originally Posted By: jruddy
Any indication of how long “eventually” is? Have there been any recent improvements in the insulation that would extend the life?
Hi jruddy:
The word eventually is vague and undefined as it was used, and the text I posted came from th 68 NEC, and it may have been in the earlier editions too.
The life of Type R rubber covered wires that were used in K&T systems, compared to the newer types developed since, have now entered into a second retirement and are usually deteriorated in less than normal conditions.
See 310.10 in the HI Guide AKA the NEC.
Existing electrical systems that were installed as K&T where they are found in walls, or in the attic where we know that the heat is a factor and determinant of operating temperature are almost always as brittle as a pretzel.
Here's a picture of some deteriorated wiring:
![](upload://sCd51Pyi4Ge4mhTKpnoVo12K6M8.jpeg)
The design/expected life of a residential building is usually 50 yrs to 75 yrs. I believe HUD uses the 75 yr figure for the entire building before a major rehabilitation or replacement is needed, and I have also heard that 50 yrs is about the maximum for a wiring system (IAEI?).
So IMHO wiring systems older than 1954 would be suspect, and warrant a closer look.
Just my 2-nickels ... ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
FEMA uses a 70 year life expectancy.
Jerry Peck
South Florida
Does anyone have a link to what IAEI’s or IEEE’s position is on the design life for wiring systems … I believe it’s considered to be 50 years. Don’t quote me on that until a good reference can be found.
Robert O’Connor, PE
Eagle Engineering ?
