Originally Posted By: egriffin This post was automatically imported from our archived forum.
I was looking at a fairly new Carrier A/C, but couldn’t find any indication of the size. Couldn’t find BTU, W or kw, or tons. Is there any particular way to determine size. It did have model and serial numbers.
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
On a carrier unit the tonnage is in the model number. I.E. 38Q042300 is a 3? ton unit (042 is 42000 BTU, 12000 BTU per A/C ton). That is actually true on any BDP unit.
Most manufacturers have the tonnage in the model number.
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Except when you get to Carrier air handlers.
Now that becomes a problem. The 002 air handler can be used with many sizes of condenser units - talked to the factory just last week on this.
Carrier used to give the size in the air handler model number, then they changed the coding.
001
002
003
004
005
006
I was told that 001 was 1 1/2 ton. That 002 was 2 ton. That 003 was 2 1/2 ton. That 004 was 3 ton. That 004 was 3 1/2 ton. That 005 was 4 ton. That 006 was 5 ton. Yep, they said no 4 1/2 ton.
Then I call next week to clarify that I was told right. And find out I was told wrong.
The 002 can be used with condenser units from 2 ton to 4 ton, depending on various other things the a/c contractor is trying to accomplish. But the 003 can be used from 2 ton to 4 ton too.
I stopped asking as it really did not matter any more. I was told that the only way to know was to call the a/c company which installed the units and have them explain their sizing choice to me. That is not going to happen.
Originally Posted By: Vince Santos This post was automatically imported from our archived forum.
Waayyy to much trouble in my opinion. I guess that would get an “unable to determine size” in my report. Of course it’s always nice to be able to go the extra mile for your client. I believe they would appreciate the effort. And of course a satified customer equates to more business.
– Desire is half of life, indifference is half of death.
Keep in mind that Jerry is talking about the air handler size. The compressor size, which is more important, should still be easy to determine from the model number …
– Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: dbowers This post was automatically imported from our archived forum.
Vince -
I'm in Kansas City and a 4 Ton A/C unit would be more than adequate for the average 2,600 sf house and you're in a cooler climate than I - BUT the only way to really know what is needed is to do have a competent HVAC contractor do a heat loss analysis on the home.
That requires doing things like knowing how many windows; which way does the house face; how much insulation; etc, etc. Its not a hard calculation for someone that knows how to do it - however, it can take an hour or two to do it properly.
The old rules of thimb on so much tonage per so many square feet are just that - rough guesstimates. In a hotter climate like Texas, Florida, etc the number will be lower - in a cooler climate they will be higher.
I think I should stop telling my client the size of the unit unless it’s very undersized of oversized. I don’t even know why I mentioned it during my last two inspections. On one of them my client called me a couple days later and said, “the only thing you left out of the report is if you think the unit is too large.” I made the mistake of saying out loud to him that it may be to big. From now on I will just get the numbers, determine the size and leave it at that. Unless like I said, it’s way to small or too big.
As I understand it, heat load calculations are out of the scope of a normal home inspection.
One thing I have been coming across a lot is my clients asking me how they should fix things. There are some things I think I do know how to fix as it seems obvious. For example, I saw chimney flashing the other day that was a wrong and I told my client how it should be done. Do you guys ever say how things should be fixed or just refer them to a licensed builder etc. and leave it at that?
-- Desire is half of life, indifference is half of death.
--Kahlil Gibran
I don’t give repair recommendations, but I’m sure there are many inspectors who do. I’ve been out of construction for quite a while, so there may just be a better way to do something that I haven’t kept up with!
I also just follow the basic HI guideline. Observe and report.
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
AS HI’s doing calcs to determine size is beyond our scope. Not that it’s bad, but it is beyond our scope and you better be sure of your calculations or you’ll be liable.
Originally Posted By: psabados This post was automatically imported from our archived forum.
More important than trying to size the unit, verify that you have adequate air flow at ALL registers.
Had one awhile back that was a relocated unit with a new garage added on to the side. Above the garage and part of the old MBR the builder created a very nice size master suite about 800 s/f. Six vents installed at various points in the floor along the walls. Only ONE was allowing conditioned air into the room and that was only just over 200cfm. Someway or somehow the other 5 ducts were disconnected or blocked. All finishes completed and of course all duct work was hidden. Builder/remodeler refused to repair, deal fell through and the house is still on the market. Was the buyers agent upset? Nope, she was my client.
Watch the air flow on dwelling that are on-grade with ducts in the concrete slab. No telling what's happened below grade in the past, ie. water penetration into the duct system.
