determining seer?
Is it true that to determine the seer you need to have the model number of the evap coil as well as the condenser?
What is the seer on this condenser? I am thinking 15 based on model
According to the mfr:
14ACX meets or exceeds 14.00 SEER,*** (Seasonal Energy Efficiency Ratio)
***Actual system efficiency may vary depending on the exact system match. Efficiencies are representative of a single AHRI Most Popular matched combination. Always verify actual system efficiencies through AHRI or by visiting AHRI ratings database at www.ahridirectory.org
Thanks Steve.
Why do you want to know this?
If someone is questioning the install, you need both and call the Mfg.
