Would your consider this normal or a defect i couldn’t decide today.
I’ve seen this go around on various HI and electrical forums over the years and the “rainbow” colored metal is generally considered as normal. Those pics are a bit different than what I’ve seen but I can’t say it’s dangerous or abnormal. Was there any sign of water collection in the base of the panel or elsewhere? When I inspect a panel for performance defects I’m mainly looking for scorching at attachment points and that doesn’t seem to be that.
It almost looks like some plating is coming off…but I don’t know for sure, Cory.
From my experience working and welding metals over the years, the ‘rainbow’ is a result of heat, and from what I see (or should I say “don’t see”) in that photo, is likely from the manufacturing process.
My first thought was also a ‘coating’, but that makes no sense in an electrical panel at that location.
I’ve seen rainbows from over heating before and this was defiantly not like that. I didn’t see anything else wrong in the panel just this discoloration.
It is just the plating discoloring. Nothing to note.
Hard to tell from MI. You have good eyes Joe.
Not really, I have seen this on panels coming down the assembly line when I was at the SQ D plant in Mexico.
Well, there you go…experience pays off.
Could a lack of anti-oxidant paste on the aluminum conductors cause this discoloration?
I’ve seen this on several GE panels and it’s perfectly normal without some of other indicator of an abnormality like a melted conductor.
