Disposal Outlet
Does a disposal outlet mounted under the kitchen sink require a GFCI if installed on a switch above the countertop?
No, only outlets serving the counter
Not to confuse a correct answer, but more specifically, receptacle outlets serving counter tops…
You are correct sir. A common error on my part.
The receptacle under the sink does not require GFI protection.
