Do most of you test 240V dryer receptacles with a multimeter during a standard home inspection?
I recently had a situation where a dryer receptacle showed power present with a non-contact voltage tester, but an electrician later stated the receptacle had two hot legs and no neutral. The electrician told the client I should have caught it.
I understand that a multimeter test from the receptacle face could verify hot-to-hot, hot-to-neutral, and neutral-to-ground readings without disassembling the receptacle. My question is whether this is something most home inspectors are routinely doing as part of a standard visual home inspection, or whether you consider that electrical troubleshooting/diagnostic testing beyond the normal scope.
For those who do test them, are you testing every accessible 240V dryer/range receptacle with a meter, or only when there is a visible concern or appliance operation issue?
Just trying to compare common practice and improve my process where needed.
In Texas we are required to test all accessible 240V receptacles. I use a multimeter for the reasons you state.
Where appliances are connected, typically range and dryer, those are tested to ensure they properly function as the outlet is not accessible/safely accessible without pulling the appliance away from the wall. Since we are required to test the range heat that ensures it has proper power. For the dryer, as long as there are no clothes in it, a 10 minute run heats it up sufficiently to determine that it is functioning.
Yes, I do. I had a client several years back after they moved in said the dryer wasn’t working. The tumbler would spin but it didn’t get hot. The receptacle only had one hot leg. I’ve been testing them ever since and have found several that were incorrect one way or another.
As George said it only takes a few seconds.
In your defense, you are not required to insert any tools or probes into any electrical devices. But if there was a wiring issue, it’s possible that you should have caught it.
Can you be more specific? What did the electrician mean by “two hot legs and no neutral“?
Did he literally mean a two wire circuit without a shared ground/neutral connected to a 3-prong receptacle? Was it a three wire circuit (10-2 with ground) connected to a 4-prong outlet?
Did he simply just mean that it was a three wire circuit connected to a 3-prong receptacle without a dedicated neutral(shared with ground)?
I feel that this is an important topic so thanks for posting. Others have made great points to which I agree. The problem with a non-contact voltage tester is that a positive reading for voltage does not necessarily confirm that proper voltage is present to “power” the intended device. It only confirms that “some” voltage is present which could also indicate stray or phantom voltage.
Morning, Jerry. Pleasure meeting you. Hope to find you well.
Like George, I use a Wiggy, (a solenoid-type voltage tester) when ta 240V outlet is accessible.
Inexpensive tester. A “wiggle test” verifies the integrity of electrical circuits and connections to pinpoint intermittent faults or loose wires.
I just want to remind people who test 240V receptacles that you cannot completely verify whether a 4-prong receptacle is wired correctly with a multimeter or wiggy.
the two hots will give 240V
hot-neutral will give 120V
Hot-ground will give 120V
the problem is whether the white neutral wire actually goes to the neutral slot on the receptacle, or bare ground wire goes to the ground slot, because both of these will show 120V with the hot on a wiggy or multimeter. TO VERIFY THIS, YOU MUST REMOVE THE COVER PLATE(At least) AND MAY NEED TO PULL OUT THE RECEPTACLE(depending on how badly the wires are jammed in the box). Otherwise you’ll run into the potential for neutral current on the grounded parts of the dryer.
While that is true, in the past and still in many older homes, neutral current was on the dryer frame and body as the neutral was bonded to the dryer frame.
For those homes purchasing a new dryer with an older 3 wire 240v outlet the older cord is still available. During installation be sure to bond the neutral to the dryer frame (usually via a grounding strap).
Okay, I see that I wasn’t clear enough with what I was trying to convey. I wasn’t talking about updating an old 3 wire dryer circuit with a 3-prong receptacle to a 4-prong receptacle, which yes you have to add a separate wire for that to work.
I was talking about why old homes had 3-prong receptacles but the code was changed to have newer homes built with 4-prong receptacles for dryers, which was a result of the “potential” for current to go on the frame or chasis of the appliance.
What you said, “old 3-prong receptacles are replaced with 4-prong receptacles” ties very closely with the image Bob posted which says, “The home inspector should recommend that the 3-prong outlet be upgraded to a 4-prong”, which is horrible advice without also recommending updating the wiring.
