Over splash out of the tub.
I recommend a trough drain around the entire perimeter of the tub. Maybe a sign that says “if you splash water out of the tub the floor will get wet.”
Run downspout through floor and tie into drain piping!
Water sensors to alarm deep thinker in tub the floor is wet.
Sounds like a fool-proof system!
Iron clad idiot proof.
I just need a helpful lady help me shower and dry me out
Simon are you going to let soap up those hard to reach places too?
That will never happen…there is always one that doesn’t get it.
Don’t get carried away now, sensitive minds are present!
Is that Simons towel holder?
OMG Roy, I feel really bad for you! Sorry brother!
That’s “your” lady you are looking for…
Looks like I got something in her hair
What little water on that ledge won’t amount to diddly and should be wiped dry after use anyways.
I would be more concerned about how do you change the faucets and spray if they go bad.?
I see that too often Marcel, Nice tub but no access to the plumbing!
I’d be calling that out way before water on that ledge.
On a sidenote I have never seen a Roman tub filler spout with a drain pull rod coming out of the spout. I wonder if these are widespread lavatory faucets mounted on a soaker tub?
Emil did you pull on the tub spout pop up drain rod coming out of the tub spout? Is there a diverter I don’t see for the hand held shower?
