If you have employees you could be responsible like this .
Bulletin
Ottawa Catholic School Board Fined $250,000 in Death of Maintenance Worker
March 31, 2016 4:30 P.M.
Ministry of Labour](https://news.ontario.ca/mol/en)
OTTAWA, ON - The Ottawa Catholic School Board pleaded guilty and has been fined $250,000 in the death of a maintenance worker.
The death took place on January 9, 2015, at the board’s St. Nicholas Adult High School located at 893 Admiral Avenue in Ottawa. The worker was employed by the board and worked at a number of different schools; on this day the worker was assigned the task of replacing a safety cage on a ceiling light in the school’s gymnasium.
The worker was working alone, and was provided with a van, a trailer with a ramp and a portable aerial device (a type of lifting device), all owned by the OCSB. Upon arrival, the worker shoveled snow out of the way, opened the trailer and lowered the ramp, which was attached to the end of the trailer. The ramp was wood with a metal plate. The ramp stood about 13 inches high at the trailer and sloped down to the ground; the length of the ramp was about 7 feet, three inches.
The angle of the ramp was about eight degrees. The manual for the aerial device indicated that the aerial device should not be rolled down an incline greater than five degrees.
The aerial device was in two parts. One part had the battery and basket and was on a dolly; the other part was on four wheels and had a metal mast folded together on one side of it. The mast end of the aerial device, which was the heavier side of the aerial device, was on the lower side of the ramp, and pointed down toward the ramp and not toward the van.
While rolling the aerial device with the mast down the ramp, the aerial device tipped over and struck the worker fatally.
The OCSB pleaded guilty to failing as an employer to take every precaution reasonable in the circumstance for the protection of a worker. It failed to ensure that:
- [FONT=“Open Sans”]the angle of the ramp was five degrees or less;[/FONT]
- [FONT=“Open Sans”]the ramp and the ground surface were free of ice or snow;[/FONT]
- [FONT=“Open Sans”]the aerial device with the mast was rolled down the ramp with the mast on the upper or high end of the ramp (toward the van) to lessen the possibility of it tipping;[/FONT]
- [FONT=“Open Sans”]another worker was present to assist the worker.[/FONT]
[FONT=“Open Sans”]The guilty plea was accepted in Ottawa court and Justice of the Peace Jacques Desjardins imposed a fine of $250,000 in the courthouse at 100 Constellation Crescent, Ottawa, on March 31, 2016.[/FONT]
[FONT=“Open Sans”] In addition to the fine, the court imposed a 25-per-cent victim fine surcharge as required by the Provincial Offences Act. The surcharge is credited to a special provincial government fund to assist victims of crime.[/FONT]
