I’ve seen Branch II Pest Control (“termite company”) inspectors in action and they will use an XXXL screwdriver to check for dryrot on eves and rafter tails, giving them a pretty good poke, like enough to cause at least hairline fracture in paint and leave a mark.
Is that normally allowed for non-termite company Home Inspectors? IIRC their Reports will SAY “visual only”, etc.
I use a blunt probe, it leaves no marks on paint or wood if it’s in good condition. Rot is usually found around exterior windows around posts that are touching concrete and floor joists in the crawlspace.
Termite damage is mostly found in crawlspaces around here, as it’s the easiest access for termites.
I would never use a screwdriver or a knife for probing.
My probe can be attached to a doca pole for east access to tall areas.
This method is Non-invasive. I’m just discovering hidden damage. I’m not cutting holes in the house to fine it, that would be invasive.
ndegaris
(Neil DeGaris, CMI® KY License # 102167)
7
