Code or not ?
http://i1357.photobucket.com/albums/q752/Greg_Pownall/FromSkitch_zps7fb9f327.png
Leads to 100A sub…
http://i1357.photobucket.com/albums/q752/Greg_Pownall/photo_zps29933f82.jpg
Code or not ?
Leads to 100A sub…
That don’t look right at all. 3 different wire gauges too it looks like. I cant read the numbers from the photo.
looks like a 2/0 a 1/0 and an 8?
-Carl
Is that a ground tapped with a neutral?
The whole thing just looks weird, don’t it!
-Carl
Greg, where do you find this stuff? your running around Dunbar?
It does indeed and one should recommend further evaluation by a Licensed electrician and hope it’s not the same one who did this.
Why would you need further evaluation. It is wrong and needs to be corrected.
Here is one I called out and the electrician said it was fine.:roll:
Not code, not right. Subpanels must be on their own breaker from main panel, not double tapped into main lugs.
Wow, are you sure he was an electrician?
NOT…
I had one of these last week that was set up for a backfeed generator. Reinspection required, the owner just removed the subpanel.
Makes me wonder sometimes
I also run into all kinds of garbage down in my neck of the woods. Owner rehabs with work performed by their cousins, uncles and family friend. When I tell them it needs repair, they stare at me like I have three heads!..lol. Simply amazing.
Bert
