Double tapping in main panel
Originally Posted By: ecox1
nuetral wire and the ground tapped together
Originally Posted By: bking
Not Ok, neutrals are current carrying conductors in 120v circuits, they should be terminated with one screw per wire. Grounds are usually ok double tapped but should be seperate if space permits.
www.BAKingHomeInspections.com
so u saying in other words I should refer this to and electrician
yes, anything incorrect with electrical requires an electrician
Originally Posted By: chorne
I would not call neurtal and ground termination together “double tapping”
Carla
chorne wrote:
I would not call neurtal and ground termination together "double tapping"
Carla
thanks carla ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
Originally Posted By: escanlan
Quote:
E3306.9 Terminals.
Connection of conductors to terminal parts shall be made without damaging the conductors and shall be made by means of pressure connectors, including set-screw type, by means of splices to flexible leads, or for conductor sizes of No. 10 and smaller, by means of wire binding screws or studs and nuts having upturned lugs or the equivalent. Terminals for more than one conductor and terminals for connecting aluminum conductors shall be identified for the application.
Manny (Emmanuel) Scanlan
Knowledge is power, but sharing knowledge brings peace!
Originally Posted By: pabernathy
Ok, We do not really deal much with IRC in regards to the electrical trade and with regards to inspections as much…more over the NEC would govern this most of the time.
However as previously stated it has been a violation for years under the UL standards but in 2002 the NEC made it clear of the violation and listed it as such.
Use the search feature in this forum and you will find a long discussion on the topic.
Paul W. Abernathy- NACHI Certified
Electrical Service Specialists
Licensed Master Electrician
Electrical Contractor
President of NACHI Central Virginia Chapter
NEC Instructor
Moderator @ Doityourself.com
Visit our website- www.electrical-ess.com
