This panel is a sub panel down stream from the main panel to the home. Aren’t the grounds and neutral suppose to be separate? Would you just add an additional bus bar? And can you explain the reason why this should be done. I could not find anything on this in any of the message boards.
[ATTACH][/ATTACH]
Thanks
