I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
This one looks really good Zak, I have no suggestions for improvement.
Even though the point of the image is the about joist requirements, you should consider adding ledger flashing to any image that includes a ledger attachment to a home, to help eliminate confusion for new inspectors and others unfamiliar with deck construction. Having some images with and some without could lead to a lot of ???
On another note, the post should be noted as 6×6 minimum size for notches to accommodate beams w/ no less than 2 1/2" of solid wood remaining on the post. 4×4 posts cannot be notched.
Title should be changed to specify (exterior) DECK Joists.
This would absolutely NOT be correct for main home Cantilevered Joists!
Image has been updated, hit refresh.
Thank you!
