Draft image: Exterior Stairs and Guards Inspection
I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
Is there a minimum width on the handrail that would deem it graspable? I have come across some that are barely a 1/2 inch overhang on the outside of the railing. Not much to grasp on.
Also, a maximum width on the handrail to be classified as ‘graspable’.
That’s good for mainly interior railings, but for decks with the flat railings needs to be shown.
I apply the graphic to exterior handrails and handrails at decks too. I call out tons of deck stairs for not having graspable handrails. Many of them have a 3-1/2" wide or wider board on top of the guardrail, which doesn’t count as a graspable handrail.
Cool beans. I usually differentiate between the two. But to each, their own. :wink:
Absolutely…
You should indicate that these requirements are for residential and not commercial application. Also, indicate the 10" tread depth is measured leading edge to leading edge(nose to nose). With a 1" overhang, you will only have a 9" tread depth, which is not compliant.
