Draft image: Foundation Cracks: Differential Settlement
I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
I suggest:
“Weak or unstable load bearing soils can create unbalanced loads on the footings, floor slab and foundation walls leading to bending and cracking of these concrete structural elements.”
Adding a footing with a crack through it would be good too.
Concrete floors and concrete footings are not poured in one plane.
They are separate pours and separate planes, typically.
Concrete is not meant to be poured but cast in place. if its being poured, it has had too much water added to the mix which weakens it substantially.
That may be.
But I never heard someone say they were going to cast the footings or floor. :face_with_spiral_eyes: :sweat_smile:
I agree with you on that. That’s because so many concrete subs do 'pour" it when they have the driver dump many gallons of extra water into the mixer after it came from the plant ready mixed and at the proper slump. Doing this allows the workers to leave the job sooner and more rested and they can get to the bar earlier.
