Draft image: Masonry Wall Damage: Rising Moisture and Improper Drainage
I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
That’s a great graphic of a common problem found in the field. The brick is often buried below the soil line when it should be supported on a foundation wall with at least 4 inches of foundation showing above the soil line. This condition is commonly referred to as “the rising damp”.
The “exterior wall” label could be removed. This issue occurs at both the interior and the exterior. Also, we have green grass on both sides of the wall, whereas one side would be assumed to be the interior.
Image has been updated, hit refresh.
Thank you!
